OA116 Crossover rebuild kit - wanted to buy
wesfyck
Post by wesfyck » Thu 15 Mar 2018, 20:02
Greetings Sonab fans and CarlssonPlanet:
I have a set of 116's and would like to buy either a crossover rebuild kit or two new complete working crossovers.
Can anyone here help?
Sincerely, Wes
Re: OA116 Crossover rebuild kit - wanted to buy
Post by Martin Dellstig » Fri 16 Mar 2018, 09:40
Hi
What is it you want to do with your speakers?
Restore or upgrade?
Do you still have the old filters?
What tweeters are mounted on the speakers?
With some more info we can give you better help.
There are, as I see it, two main Courses of action:
- restoration with the old Peerless tweeters MT24HFC (can be MT20HFC if it is an early production).
- Upgrade with the new tweeter OBI T22oa http://www.hifikit.se/hogtalarelement/h ... ant/t22-oa
Please enlighten us and we'll try to give some better advice.
The more we now, the more precise answer!
Best regards
wesfyck
Post by wesfyck » Tue 17 Apr 2018, 17:18
Hi Martin: Thanks for getting back to me. My speakers are still equipped with original tweeters and all I want to do is restore what I have. The lower woofer on my left speaker is not working, though the driver itself is fine (checked). I hope that helps. I look forward to hearing back from you as to what you can do for me.
Thanks
Wes
Post by momus » Tue 17 Apr 2018, 22:21
Consult Anders Forsberg (Grafpro) at Carlssonkult.se. He writes and understands English.
Post by Martin Dellstig » Wed 18 Apr 2018, 09:57
Hello
Start by checking all the leads in the bottom of the loudspeaker. There you have the first part of the crossover that is relevant for the woofer.
You have to look/test a bit but it should not be too difficult.
Keep us posted!
Best regards
