a116 Restore Wiring Help!
kolakidd
Re: a116 Restore Wiring Help!
Post by kolakidd »
Thank you.
I have replaced the speaker terminals, but I think I need to replace all PCB connectors and all crimp receptacles.
kolakidd
Post by kolakidd »
Unfortunately I have isolated the problem as the tweeters themselves. I've disconnected them and played a signal through the and the distortion is with the tweeters themselves. I've tried to seal up the edges of the tweeters with a flexible speaker glue as described in other posts, but that has not helped.
I cannot afford the T22-OA, I'm not based in Europe and the exchange rate and transportation costs make those prohibitively expensive. Any recommendation on possible repairs or alternative tweeters would be greatly appreciated.
Russ
Post by Russ »
Some people have tried Monacor DT-28N tweeters and found it ok.
I do not know if you can buy the tweeters in US and I know nothing about them.
kolakidd
Post by kolakidd »
Thanks Russ, I will check those out.
I'm actually based in South Africa, our exchange rate is way, way, worse than the USD.
