Sonab OA14
Jonny virago
Sonab OA14
Post by Jonny virago »
Hello I have a Sonab OA14 with a busted driver. Does anyone know if the 6.5 inch driver from a Sonab C-21 will fit and be a good match.
Re: Sonab OA14
It might fit in the hole. But it´s a slim chance it will be a good match. The Sonab C-21 is a more modern speaker from a totally different company that bought the name "Sonab".
The correct speaker today to buy is B65oa-IV. https://www.hifikit.se/catalogsearch/result/?q=b65
But they are not available at the moment in the 8 ohm version. You have to wait for them.
What do you mean with "busted"? If it's the foam surroundings they are possible to replace. Check both drivers.
Jonny virago
Re: Sonab OA14
The copper voice coil is damaged and sticks in the groove. I messaged hifikit but they did not reply.
quadmatrix82
Re: Sonab OA14
Post by quadmatrix82 »
Hopefully someone here has one for you i see them on eBay occasionally if you want the original
